Morning Report
Your watch displays a morning report based on your normal wake time. Press DOWN, and select Checkmark symbol to view the report, which includes weather, sleep, overnight heart rate variability status, and more (Customizing Your Morning Report).
NOTE: You can customize these settings on you watch or in your Garmin Connect™ account.
  1. Hold UP.
  2. Select Appearance > Morning Report.
  3. Select an option:
    • Select Show Report to enable or disable the morning report.
    • Select Edit Report to customize the order and type of data that appears in your morning report.
    • Select Your Name to customize your display name.
    • Select Clocks to set an alarm (Setting an Alarm).
June 2025
