Customizing the Controls Menu
You can add, remove, and change the order of the shortcut menu options in the controls menu (Viewing the Controls Menu).
  1. Hold UP.
  2. Select Appearance > Controls.
  3. Select a shortcut to customize.
  4. Select an option:
    • Select Reorder to change the location of the shortcut in the controls menu.
    • Select Remove to remove the shortcut from the controls menu.
  5. If necessary, select Add New to add an additional shortcut to the controls menu.
June 2025
