Installing the Shoe Cleats for Rally XC
NOTE: The left and right cleats are the same.
  1. Inside your shoe, lift the insole and insert the 2-hole cleat mount Callout number 1 and the insole washer Callout number 2.
  2. Apply a thin layer of grease on the cleat bolt threads.
  3. Align the cleat Callout number 3, washer Callout number 4, and bolts Callout number 5.
    Exploded view of the shoe cleat with glyphs
  4. Use a 4 mm hex key to loosely attach each bolt to the sole of the shoe.
  5. Adjust the cleat to the shoe in your preferred position.
    This can be adjusted after a trial ride.
  6. Tighten the cleat firmly to the shoe.
    NOTE: Garmin® recommends a torque of 4 to 6 lbf-ft. (5 to 8 N-m).
GUID-F384D11E-79B0-4D97-BB69-DD8922C20299 v5
July 2024
