Connecting the Fusion PartyBus Device to a Wireless Access Point
  1. Select Apps > Tools > Music > Settings > Network > WI-FI CLIENT > SSID.
    A list of wireless access points within range appears.
  2. Select the Fusion PartyBus™ wireless access point.
  3. Select an option:
    • To enter the password, select Password, enter the password and select Enabled.
    • If you are connecting to the wireless access point using WPS, verify that WPS has been enabled on the access point and select WPS.
      NOTE: It can take up to two minutes to successfully connect to the access point after you select WPS.
  4. Select Save.
GUID-F2A144DD-76F7-44EF-AADF-270AAAC241A9 v5
August 2025
