Map and Software Updates
Map updates provide the newest available changes to roads and locations in the maps used by your device. Keeping maps up to date helps your device find recently added locations and calculate more accurate routes. Map updates are large and may take several hours to complete.
Software updates provide changes and improvements to the device features and operation. Software updates are small and take a few minutes to complete.
The display device downloads software updates for both the display and the stereo dock simultaneously. If you update the display while it is disconnected from the stereo dock, the display prompts you to update the stereo dock software the next time you connect it to the stereo dock.
You can update your device using two methods.
You can connect the device to a Wi‑Fi® network to update directly on the device (recommended). This option allows you to update your device conveniently without connecting it to a computer.
You can connect the device to a computer and update it using the Garmin Express™ application (garmin.com/express).
