Specifications
Display Specifications
Operating temperature range
From -20 to 55°C (from -4 to 131°F)
Charging temperature range
From 0 to 45°C (from 32 to 113°F)
Radio frequency (Vieo™ RV 851/852)
2.4 GHz @ 14 dBm maximum
Radio frequency (Vieo RV 1051/1052)
2.4 GHz @ 15 dBm maximum
Power input
Vehicle power using the included vehicle power cable. AC power using an optional accessory (for home and office use only).
Battery type
Rechargeable lithium-ion
Dock Specifications
From -10 to 55°C (from 14 to 131°F)
Storage temperature range
From -20 to 70°C (from -4 to 158°F)
Input voltage
From 10.8 to 16 Vdc
Current (max.)
15 A
Current (standby mode)
Less than 5 mA
Fuse
15-A mini blade type
Wireless frequency/protocol
2.4 GHz @ 7.9 dBm nominal
On-board, Class-D Amplifier
Output music power per channel
4 x 70 W max., 2 ohm
Total output peak power
280 W max.
Output power per channel
4 x 43 W RMS at 14.4 Vdc input, 2 ohm, 10% THD1
4 x 26 W RMS at 14.4 Vdc input, 4 ohm, 10% THD2
Line output level (max.)
5.5 V (peak to peak)
Aux. input level (typical)
1 V RMS
Tuner
Europe and Australasia
USA
Japan
FM radio frequency range
87.5 to 108 MHz
87.5 to 107.9 MHz
76 to 95 MHz
FM frequency step
50 kHz
200 kHz
50 kHz
AM radio frequency range
522 to 1620 kHz
530 to 1710 kHz
522 to 1620 kHz
AM frequency step
9 kHz
10 kHz
9 kHz
1 The stereo may limit the output power to prevent the amplifier from overheating and to maintain the audio dynamics.
2 The stereo may limit the output power to prevent the amplifier from overheating and to maintain the audio dynamics.
GUID-F2A144DD-76F7-44EF-AADF-270AAAC241A9 v5
August 2025
