Formatting the Memory Card
The device requires a memory card formatted using the FAT32 file system. You can use the device to format your card using this file system.
You must format a brand new memory card if it is not formatted using the FAT32 file system.
NOTE: Formatting the memory card deletes all data on the card.
  1. Select Apps > Tools > Settings > Storage & USB.
  2. Select your memory card.
  3. Select Settings > Settings > Format > ERASE & FORMAT.
  4. Select Done.
GUID-F2A144DD-76F7-44EF-AADF-270AAAC241A9 v5
August 2025
