RCA Wiring Harness Wire and Connector Identification
Faisceau de câbles LED de l'appareil avec légendes
Wire Number
Wire Function
1
Auxiliary in left: Provides a red and white RCA stereo line input for audio sources, such as a CD or MP3 player.
Auxiliary in right: Provides a red and white RCA stereo line input for audio sources, such as a CD or MP3 player.
2
Line out left: Provides a full-range output to an external amplifier, and is associated with the volume control.
Line out right: Provides a full-range output to an external amplifier, and is associated with the volume control.
REMARQUE : If you are connecting to an external amplifier, you should use a ground loop isolator to ensure a clear signal.
3
Subwoofer out: Provides a single mono output to a powered subwoofer or subwoofer amplifier.
GUID-F0AC3576-CD83-465E-983D-7AD585ADB59E v7
Décembre 2025
