Wire Gauge Guide
If necessary, you can use longer cables for your installation.
NOTA:
If you are using aluminum or tinned wire, you should use a wire two gauges larger than the gauge listed below to compensate for a potential voltage drop due to the wire material.
Use 16 AWG (1.31 mm2) for speaker wires.
Use 20 AWG (0.52 mm2) for LED wires.
Tema principal: Wiring
