RCA Wiring Harness Wire and Connector Identification
Wire Number |
Wire Function |
Auxiliary in left: Provides a red and white RCA stereo line input for audio sources, such as a CD or MP3 player. Auxiliary in right: Provides a red and white RCA stereo line input for audio sources, such as a CD or MP3 player. |
Line out left: Provides a full-range output to an external amplifier, and is associated with the volume control. Line out right: Provides a full-range output to an external amplifier, and is associated with the volume control. NOTA:
If you are connecting to an external amplifier, you should use a ground loop isolator to ensure a clear signal.
Subwoofer out: Provides a single mono output to a powered subwoofer or subwoofer amplifier. NOTA:
Tema principal: Connections
