Connecting the Device to Vehicle Power
You should always confirm all electrical connections are secure and will not come loose while operating the device.
NOTICE
If the ignition wire is not used, do not tie the ignition to the positive terminal on the vehicle battery. Ground the ignition wire or leave it disconnected. Failure to ground or disconnect the ignition wire when the ignition is not used could prevent the device from powering on.
  1. Remove the terminal cover 1 using a Phillips screwdriver.
    Line drawing of the device with the terminal cover being removed with callouts
  2. Remove the screws from the GND terminal and the +12V terminal 2.
  3. Connect the large ring end of the included ground wire 3 to the negative terminal on the vehicle battery.
    Device power wiring with callouts
  4. Connect the small ring end of the ground wire to the GND terminal 4 on the device.
  5. Tighten the screw on the GND terminal.
    You should confirm the screws cannot be loosened by hand.
  6. Connect the small ring end of the included 12V cable to the +12V terminal 5 on the device.
  7. Tighten the screw on the +12V terminal.
    NOTICE
    Do not overtighten the screw on the +12V terminal to prevent damage to the terminal.
  8. Connect the large ring end of the 12V cable 6 to the positive terminal on the vehicle battery.
  9. Replace and tighten the terminal cover on the device.
GUID-F0AC3576-CD83-465E-983D-7AD585ADB59E v7
December 2025
