Wire Gauge Guide
If necessary, you can use longer cables for your installation.
NOTE: If you are using aluminum or tinned wire, you should use a wire two gauges larger than the gauge listed below to compensate for a potential voltage drop due to the wire material.
  • Use 16 AWG (1.31 mm2) for speaker wires.
  • Use 20 AWG (0.52 mm2) for LED wires.
GUID-F0AC3576-CD83-465E-983D-7AD585ADB59E v7
December 2025
