Customizing the Map
Customizing the Map Layers
  1. From the map, select Map layers > Layers.
  2. Under Map Type, select a map type.
    With some map types, you can select Context menu > Hybrid Map to combine two map types.
    NOTE: The Satellite Imagery map shows satellite images only for areas where you have downloaded satellite imagery (Downloading Outdoor Maps+ Content).
  3. Under Map Details, select the types of information to display over the map.
    NOTE: Some layers are incompatible with each other and cannot be enabled at the same time. Enabling a layer automatically disables any incompatible layers.
    NOTE: Some map layers require an Outdoor Maps+ subscription.
Before you can download Outdoor Maps+ content, you must purchase an Outdoor Maps+ subscription. Go to garmin.com/outdoormaps for more information.
You must connect your device to Wi‑Fi® before you can download Outdoor Maps+ content (Connecting to a Wireless Network).
To see Outdoor Maps+ content on the map, you must download the content for a specific area.
NOTE: Some Outdoor Maps+ layers are available only in certain areas.
  1. Select Settings > Map Display > Map Manager > Outdoor Maps+ > Download Maps.
  2. Drag the map and pinch to zoom in and out on the map until the highlighted rectangle covers the area for which you want to download map data.
    TIP: As you change the size of the area, the total download size and your current disk usage appear at the top of the screen.
  3. Select Layers with plus sign.
  4. Select each map layer you want to download.
    TIP: You can touch Context menu to see information about each map layer.
    The selected map layers are marked with a checkmark.
  5. Select Back.
  6. Select Arrow Down to start downloading.
    You can continue using your device while it downloads Outdoor Maps+ content.
Viewing the Map Key
Elements on each map layer are color-coded to represent different information. You can view the map key to see what each color represents.
Select Map layers > Information.
Enabling Adventure Roads and Trails Map Layers
You can enable or disable map layers that display accessible or inaccessible roads for different types of motor vehicles.
  1. Select Settings > Map Display > Map Layers > Information > Adventure Roads & Trails.
  2. Select a road or trail type.
Changing the Map Data Field
  1. From the map, select a data field.
    NOTE: You cannot customize Speed.
  2. Select a type of data to display.
Changing the Map Buttons
  1. From the map, hold a map button.
  2. Select an option:
    • To replace a map button, select a map button, and select a map button to display.
    • To remove a map button, select Delete.
  3. Select Save.
Changing the Map Perspective
  1. Select Settings > Map Display > Driving Map View.
    • Select Track Up to display the map in two dimensions (2-D), with your direction of travel at the top.
    • Select North Up to display the map in 2-D with north at the top.
    • Select 3-D to display the map in three dimensions.
    • Select Auto Zoom to Group to automatically adjust the zoom level so all riders in a group ride are visible on the map.
  3. Select Save.
GUID-F0AC3576-CD83-465E-983D-7AD585ADB59E v7
December 2025
