Starting a Route
  1. Select Where To, and search for a location (Finding and Saving Locations).
  2. Select a location.
  3. Select an option:
    • To start navigating using the recommended route, select Go!.
    • To choose an alternate route, select Alternate routes, and select a route.
      Alternate routes appear to the right of the map.
    • To edit the course of the route, select Alternate routes > Edit Route, and add shaping points to the route (Adding a Location to Your Route).
The device calculates a route to the location and guides you using voice prompts and information on the map (Your Route on the Map). A preview of the major roads in your route appears at the edge of the map for several seconds.
If you need to stop at additional destinations, you can add the locations to your route (Adding a Location to Your Route).
GUID-F0AC3576-CD83-465E-983D-7AD585ADB59E v7
December 2025
