Using In-Call Options
In-call options appear when you answer a call. Some options may not be compatible with your phone.
TIP: If you close the in-call options page, you can open it again by selecting Phone from any screen.
  • To set up a conference call, select Add Call.
  • To transfer audio to your phone, select Call in Progress on Navigator.
    TIP: You can use this feature if you want to disconnect the Bluetooth® connection and remain on the call, or if you need privacy.
  • To use the dial pad, select Keypad.
    TIP: You can use this feature to use automated systems, such as voice mail.
  • To mute the microphone, select Mute.
  • To hang up, select End Call.
GUID-F0AC3576-CD83-465E-983D-7AD585ADB59E v7
December 2025
