Viewing Your Collections on the Map
You can view your Garmin Explore™ collections directly on the map. You must enable the collections map layer to use this feature.
NOTE: If you do not assign a collection category to your Garmin Explore data, it appears as an unorganized collection.
  1. Select View Map > Map layers > Collections.
  2. Select one or more collection categories from the list.
  3. Select Save.
    Your collections appear as icons on the map.
GUID-F0AC3576-CD83-465E-983D-7AD585ADB59E v7
December 2025
