Calibrating Pitch and Roll
You can set the angle of your vehicle to zero at any time.
  1. Park your vehicle on a flat, level surface.
  2. Adjust the position of your device in the mount so you can comfortably view the screen.
  3. From the main menu, swipe to the left and select Pitch and Roll > Calibrate.
The values for pitch and roll reset to 0 degrees.
WARNING
To maintain the best accuracy, you must calibrate pitch and roll each time you reposition your device.
GUID-F0AC3576-CD83-465E-983D-7AD585ADB59E v7
December 2025
