Mounting the Wireless Remote
  1. Select an appropriate location for the remote control (Wireless Remote Mounting Considerations).
  2. Test the range at the selected location by holding the wireless remote at the location, pressing a few buttons, and confirming the correct operation.
  3. Thoroughly clean and dry the mounting surface using a mixture of water and isopropyl alcohol.
    The mounting surface must be free of dirt, debris, wax, or coatings.
  4. Place the wireless remote on the mount, and rotate the remote until you hear a click.
  5. Remove the backing from the adhesive.
  6. Carefully orient the wireless remote in the mount with the Fusion® logo at the bottom.
    NOTICE
    It is extremely difficult to remove the adhesive. Some mounting surfaces might be damaged after removing the adhesive.
  7. Press the wireless remote in the mount firmly onto the mounting surface, maintaining pressure for at least 60 seconds.
GUID-F0AC3576-CD83-465E-983D-7AD585ADB59E v7
December 2025
