Adding Propane Tanks
NOTE: This feature is not available on all product models.
When you add your propane tanks to your vehicle profile, the device avoids routing through areas with propane tank restrictions that may affect your route. The device also alerts you when you approach areas that require you to shut off your propane tanks.
  1. From the vehicle profile, select Settings > Propane Tanks > Add Tank.
  2. Enter the weight of the propane tank, and select Save.
GUID-F0AC3576-CD83-465E-983D-7AD585ADB59E v7
December 2025
