Acquiring GPS signals
When you turn on your navigation device, the GPS receiver must collect satellite data and establish the current location. The time required to acquire satellite signals varies based on several factors, including how far you are from the location where you last used your navigation device, whether you have a clear view of the sky, and how long it has been since you last used your navigation device. The first time you turn on your navigation device, it may take several minutes to acquire satellite signals.
  1. Turn on the device.
  2. Verify Location services status appears in the status bar. Enable location services if it does not (Enabling or Disabling Location Services).
  3. If necessary, go to an open area with a clear view of the sky, away from tall buildings and trees.
    Change search area appears at the top of the navigation map until the device determines your location.
GUID-F0AC3576-CD83-465E-983D-7AD585ADB59E v7
December 2025
