Map settings
Select Settings > Map Display.
Map Vehicle Icon
Sets the vehicle icon that represents your position on the map.
Driving Map View
Sets the perspective used while viewing the map.
Map Detail
Sets the level of detail on the map. More detail may cause the map to be drawn more slowly.
Waypoint Labels
Sets the size of waypoint labels on the map.
Waypoint Decluttering
Hides waypoint icons at high map zoom levels.
Range Rings
Shows rings on the map, representing distance from you. The distance to the innermost ring appears in the bottom left-hand corner of the screen.
NOTE: Range rings are shown only while using the Track Up or North Up map perspective (Changing the map perspective).
Auto Zoom
Automatically selects the zoom level for optimal use of your map. When disabled, you must zoom in or out manually.
Skip Next Stop Confirmation
Sets a confirmation message to appear when skipping a location on your route.
Units
Sets the units of measure.
Position Format
Sets the format used for geographical position coordinates and the coordinate system used by the map (Position Format Settings).
Map Manager
Manages maps installed on the device.
NOTE: Do not change the position format or the map datum coordinate system unless you are using a map or chart that specifies a different position format.
Select Settings > Map Display > Position Format.
Coordinate Format
Sets the position format for the location information.
Display Format
Sets the format in which coordinates will appear on the device.
Datum
Sets the coordinate system on which the map is structured.
Map Spheroid
Shows the coordinate system the device is using. The default coordinate system is WGS 84.
Enabling maps
You can enable map products installed on your device.
TIP: To purchase additional map products, go to your product page on garmin.com.
  1. Select Settings > Map Display > Map Manager > Manage Device Maps.
  2. Select a map.
GUID-F0AC3576-CD83-465E-983D-7AD585ADB59E v7
December 2025
