Planning a Route
A route can include many stops and shaping points, and it must include at least a starting location and one destination.
  1. Select Apps > Navigation > Route Planner > Add.
  2. Search for or select a location on the map to be the starting point for this route.
  3. If necessary, select a route calculation mode for the route segment.
  4. Select an option:
    • If the next point along your route is a stop, select Stop.
    • If the next point in your route is a shaping point, select Shaping.
  5. If necessary, add additional stops or shaping points.
    NOTE: The last stop you add is the route destination.
  6. If necessary, select Route destination list to rearrange the order of stops and shaping points along the route.
  7. After you have finished planning the route, select Save.
GUID-F0AC3576-CD83-465E-983D-7AD585ADB59E v7
December 2025
