Routes
A route is a path from your current location to one or more destinations.
For off-road use, you can set the device to calculate point-to-point routes in a straight line (Straight Line Routes).
The device calculates a recommended route to your destination based on the preferences you set, including the route calculation mode (Changing the route calculation mode) and avoidances (Avoiding Delays, Tolls and Areas).
You can start navigating to your destination quickly using the recommended route, or you can select an alternative route (Starting a route).
If there are specific roads you need to use or avoid, you can customise the route (Adding a location to your route).
You can add multiple destinations to a route (Adding a location to your route).
