Radio
NOTE: This feature is not available on all product models.
You can use the Radio app to create radio presets, select a radio channel and select squelch codes. To use this feature, you must connect the device and the antenna to the Group Ride mount. The Tread® - SXS Edition device configures radio settings automatically when you join or create a group ride.
Selecting a Preset
  1. From the main menu, select Apps > Adventure > Radio.
  2. Select an option:
    • To move through the available presets, select Up or Low.
    • To select a preset from the menu, select Preset.
Selecting a Radio Channel
    • To move to a different channel, select Zoom in or Zoom out.
    • To select a MURS channel from the menu, select Channel.
Adjusting the Squelch
You can adjust the squelch and change squelch modes to filter out unwanted noise and interference in your area.
    • To choose a squelch code within the current mode, select Zoom in or Zoom out.
    • To select a squelch mode, select Open (Squelch Modes).
Squelch Modes
Squelch modes allow you to filter out nearby radio users on the same channel as you.
Open
Allows a traditional squelch setting to filter out static. You can increase the squelch level to filter out unwanted noise.
CTCSS
Continuous Tone-Coded Squelch System uses an inaudible low-frequency tone before each transmission to filter out unwanted noise. You hear only others on the same radio channel who are using the same CTCSS tone frequency as you.
DCS
Digital Code Squelch uses digital codes before each transmission to filter out unwanted noise. You hear only others on the same radio channel who are using the same DCS code as you.
The CTCSS and DCS squelch modes decrease your radio range slightly.
Adding a Custom Radio Preset
  1. Select Apps > Adventure > Radio > Preset > Add.
  2. Select Zoom in or Zoom out to select a channel and squelch code.
  3. Select Save.
Selecting a Roger Tone
You can select the tone other devices play when you operate your radio.
  1. Select Apps > Adventure > Radio > Settings > Roger Tone.
  2. Select a roger tone.
    The device plays the selected tone.
  3. Select Save.
Turning the Radio Off
Select Apps > Adventure > Radio > Power > Yes.
Enabling Push-to-Talk with a Headset
You can enable push-to-talk controls for use with a compatible Bluetooth® headset. This allows you to transmit your voice using the voice dial feature on your headset.
  1. Select Apps > Adventure > Radio > Settings > Push to Talk with Headset.
  2. If necessary, follow the on-screen instructions to pair your headset with the device.
  3. Select Push to Talk with Headset.
  4. Select Tick.
Transmitting Your Voice
Before you can transmit your voice, you must pair your Tread - SXS Edition device with a compatible Bluetooth headset or connect the fist microphone.
You can transmit your voice over the radio using the connected fist microphone or a compatible Bluetooth headset.
Select an option:
  • Hold the push-to-talk button on the side of the connected fist microphone (Installing the Fist Microphone and Mount).
  • From the main menu, select Apps > Adventure > Radio > Push to Talk.
  • Use the voice dial feature on your connected Bluetooth headset (Enabling Push-to-Talk with a Headset).
    TIP: You can press the pause or stop button to manually close the radio.
    NOTE: You must enable the Push to Talk with Headset setting to use this feature (Radio Settings).
Adjusting the Radio Volume
  1. Select Apps > Adventure > Radio > Volume.
  2. Use the slider bars to adjust the volume.
Radio Settings
From the main menu, select Apps > Adventure > Radio > Settings.
Enables you to transmit your voice using the push-to-talk button on your compatible headset.
Roger Tone
Sets the roger tone the device plays when you operate your radio.
Reset Default Settings
Resets all radio settings and presets to factory default values.
GUID-F0AC3576-CD83-465E-983D-7AD585ADB59E v7
December 2025
