Connecting a FUSION NRX Remote Control
You can connect a FUSION® NRX remote control (not included) to the stereo dock using an adapter cable (not included). You can purchase an NRX remote control and the required adapter cable from your FUSION dealer.
You can connect up to three NRX remote controls directly to the stereo dock without connecting them to an additional power source. If you want to connect more than three NRX remote controls to the stereo dock, you must connect them to an additional power source. See the instructions provided with the remote control for more information.
  1. Install each of the NRX remote controls by following the instructions provided with each remote control.
  2. Route the network cable from the NRX remote control network to the location of the stereo dock.
  3. Connect the adapter cable to the CAN 1 port on the back of the stereo dock.
  4. Connect the cable from the NRX remote control network to the adapter cable.
  5. Select an option:
    • If the NRX remote control network connects to an additional power source, continue with the dock installation.
    • If the NRX remote control network does not connect to an additional power source, proceed to the next step.
  6. Turn on the stereo.
  7. On the stereo, from the music player, select Context menu > Settings > NRX Power.
    When the check box is filled, the dock supplies power and data to the connected NRX remote controls.
Copyright © Garmin. All rights reserved.GUID-EFC21AFA-2D40-45E8-8E4C-6A9EFBF01CB9 v4
