Installing the Dock in a Ford Dashboard
Before you can install the dock in the dashboard, you must install the gasket and bracket on the dock.
The product package does not include the hardware required to fasten the dock bracket to the dashboard.
  1. If necessary, remove the dashboard panel or components to reach the stereo mounting location.
  2. From inside the dashboard, connect all necessary cables and wires to the dock.
  3. Place the dock in the dashboard, and secure it using screws through the top and bottom holes of the bracket.
    Line drawing of the dock installing into the dash
  4. If necessary, reinstall all remaining dashboard components.
Copyright © Garmin. All rights reserved.GUID-EFC21AFA-2D40-45E8-8E4C-6A9EFBF01CB9 v4
