Customizing the Glances List
  1. From the watch face, press Lower-left button to view the glances list.
  2. Select Edit.
  3. Select an option:
    • To change the location of a glance in the list, select a glance, press Middle-left button or Lower-left button to move the glance, and press Upper-right button to select the new location.
    • To remove a glance from the list, select a glance, and select Delete.
    • To add a glance to the list, select Add, and select one or more glances.
      TIP: You can select Create Folder to create a folder that contains multiple glances ( Creating a Glances Folder).
You can customize the glances list to create folders of related glances.
  2. Select Edit > Add > Create Folder.
  3. Select the glances to include in the folder, and select Done.
    NOTE: If the glances are already in the glance list, you can move or copy them into the folder.
  4. Select or enter a name for the folder.
  5. Select an icon for the folder.
  6. If necessary, select an option:
    • To edit the folder, scroll to the folder in the glances list, and hold Middle-left button.
    • To edit the glances in the folder, open the folder and select Edit (Customizing the Glances List) .
GUID-EECCAC99-90D6-4AB1-9A3A-EC433D3365E2 v10
November 2026
