Dive Settings
You can customize the dive settings based on your needs. Not all settings are applicable for all dive modes.
From the watch face, press Upper-right button, select Activities, select a dive activity, press Lower-left button, and select the activity settings.
Advanced Settings
Customizes advanced settings for diving activities (Advanced Dive Settings).
Alerts
Sets the custom dive alerts for the activity (Custom Dive Alerts).
Apnea Discipline
Sets the discipline type for apnea diving.
Auto Save Timeout
Sets the length of time before the watch ends and saves a dive after surfacing.
Compass
Calibrates and sets the north reference for the compass (Calibrating the Compass Manually).
Conservatism
Sets the level of conservatism for decompression calculations for scuba diving. Higher conservatism provides a shorter bottom time and a longer ascent time.
Data Screens
Customizes data screens and adds new data screens for the activity (Customizing the Data Screens).
Display Settings
Sets the screen brightness and timeout for diving activities.
Gas
Sets the gas blend used for scuba diving.
PO2
Sets the partial pressure of oxygen (PO2) thresholds, in bar, for warnings and critical alerts for scuba diving (Dive Alerts). The PO2 Warning value is the threshold for the highest oxygen concentration level that you are comfortable reaching. The PO2 Critical value is the threshold for the maximum oxygen concentration level that you should reach.
Pool Mode
Enables pool mode for scuba diving. When the watch is in pool dive mode, the decompression lockout feature functions normally, but dives are not saved to the dive log.
Safety Stop
Sets the safety stop duration for scuba diving.
Setup Sharing
Sends or receives dive computer settings between compatible devices (Sharing Dive Settings Between Devices). For example, you can share settings between your primary and backup dive computers, or your dive computer and that of another user, such as an instructor.
Water Type
Set the water type for diving activities.
From the watch face, press Upper-right button, select Activities, select a dive activity, press Lower-left button, select the activity settings, and select Advanced Settings.
Auto Dive
Automatically starts a dive activity based on your last dive type when you begin your descent. You can use the Snooze option to temporarily disable this feature.
Deco Lockout
Enables the decompression lockout feature. This feature prevents scuba dives for 24 hours if you violate a decompression ceiling for more than three minutes.
NOTE: You can still disable the decompression lockout feature after violating a decompression ceiling. You cannot disable the decompression lockout feature after violating the dive depth limit of the watch (Exceeding the Depth Limit).
Double Tap to Scroll
Scrolls through the dive data screens when you double tap the watch. If you notice accidental scrolling, you can use the Sensitivity option to adjust the responsiveness.
Satellites
Sets the satellite system to use for dive entry and exit locations (Satellite Settings).
Tissue Loading
Displays and allows you to manage your tissue load data. You can transfer your tissue load data to another device (Sharing Dive Settings Between Devices), or you can reset your tissue load data (Resetting All Default Settings).
UP Key
Disables the Middle-left button button during dive activities to prevent inadvertent button presses.
Wrist Heart Rate
Enables the wrist-based heart rate monitor for dives.
NOTICE
It is your responsibility to use discretion when sharing information with others. Always ensure you are aware of and comfortable with the individual with whom you share information.
NOTICE
The Garmin Share feature allows you to use Bluetooth® technology to wirelessly share your data with other compatible Garmin® devices. With Garmin Share enabled and compatible Garmin devices in range of each other, you can select data to transfer to another device through a direct, secured device-to-device connection.
You can transfer dive settings between two dive computers. For example, you can share settings between your primary and backup dive computers, or your dive computer and that of another user, such as an instructor.
  1. Bring both dive computers within 3 m (10 ft.) of each other.
  2. On both dive computers, select an option based on the model:
    • On the home screen, select Dive Setup > Setup Sharing.
    • From the watch face, hold Middle-left button, and select Dive Setup > Setup Sharing.
    • From the watch face, press Upper-right button, select Activities, select a dive activity, select the activity settings, and select Setup Sharing.
    TIP: You perform a separate transfer for tissue load data from the dive mode Advanced Settings menu.
  3. On both dive computers, select Settings, and select an option for setup sharing on the pre-dive screen (optional).
  4. On both dive computers, select an option:
    • To receive dive settings, wait while the other dive computer sends the data.
    • To send dive settings, press Lower-left button, wait until your dive computer connects to the other device, and select the device.
  5. On both dive computers, confirm the data transfer (if necessary).
  6. On the dive computer receiving the data, select an option:
    • To view and accept some of the updated settings, select Review, and select the settings to apply.
    • To accept and apply all the new settings, select Apply All.
    • To reject the new settings, select Decline.
The dive computer receiving the data performs a simulated dive test to confirm the new settings and tissue load. If there is an issue with the data sharing process, the dive computer receiving the data provides more details about the issue (Troubleshooting for Dive Setup Sharing).
GUID-EECCAC99-90D6-4AB1-9A3A-EC433D3365E2 v10
November 2026
