PlaysLike Settings
During a round, press Upper-right button, and select Settings > PlaysLike.
Wind
Enables wind speed and direction to be included in the PlaysLike distance adjustments.
Weather
Enables air density to be included in the PlaysLike distance adjustments.
Home Conditions
Allows you to manually change the altitude, temperature, and humidity settings used for the air density.
NOTE: It can be helpful to set weather conditions that match where you typically play. If they do not match the conditions at your normal course locations, the air density adjustments may seem inaccurate.
GUID-EECCAC99-90D6-4AB1-9A3A-EC433D3365E2 v8
June 2026
