Recording a Voice Note
You can record and listen to voice notes using your watch's built-in speaker and microphone.
  1. Select an option:
    • From the watch face, press Upper-right button.
    • Hold Upper-left button.
  2. Select Voice Notes.
  3. Select Menu.
  4. Select an option:
    • Select Location to save your GPS location with the voice note.
    • Select Volume to adjust the speaker volume.
  5. Select Record.
  6. Say your voice note.
  7. Select Stop.
  8. Select an option:
    • Select Play to play the voice note.
    • Select Menu to rename or delete the voice note.
    • Select Save location to view the voice note location on the map.
    • Press Lower-right button, and select Library to view your voice note library.
GUID-EECCAC99-90D6-4AB1-9A3A-EC433D3365E2 v9
September 2026
