Preparing the Motor for Transducer Replacement
Before you can replace the transducer, you must perform these actions to prepare the motor.
- Disconnect the motor from the power source.
- Open the shaft cap (Opening the Shaft Cap).
- Disconnect the cables in the shaft cap (Disconnecting the Cables in the Shaft Cap).
- Remove the transducer cable from the shaft cap (Removing the Transducer Cable).
- Remove the shaft cap (Removing the Shaft Cap).
- Remove the shaft from the steering system (Removing the Shaft from the Steering Servo).
