Viewing Your Dynamic Depth
During a gas dive, the dynamic depth data screen displays your depth profile for the dive so far, along with the projected ascent plan to the surface. The ascent plan shows required decompression stops or the safety stop (if configured), as well as upcoming gas switches.
During a gas dive, press NEXT to view the dynamic depth data screen.
Dynamic depth screen with callouts
1
The amount of time required to safely ascend to the surface, including decompression stops.
2
The difference between the amount of time required to safely ascend to the surface, and the amount of time required to safely ascend to the surface if you remain at your current depth for five minutes.
NOTE: When you are not in a decompression stop, this field is replaced with the NDL Δ 3M or NDL Δ 10FT data field. This is your No Decompression Limit (NDL) time if you ascend 3 m (10 ft.) from your current depth.
3
Your upcoming stops.
GUID-EBD9D9CA-112E-4044-A2C9-354D565B9A10 v3
August 2026
