Device Care
NOTICE
Do not use a sharp object to clean the device.
NOTICE
Avoid chemical cleaners, solvents, and insect repellents that can damage plastic components and finishes.
NOTICE
Thoroughly rinse the device with fresh water after exposure to chlorine, salt water, sunscreen, cosmetics, alcohol, or other harsh chemicals. Prolonged exposure to these substances can damage the case.
NOTICE
Do not wash the device under high pressure, because jets of water or air may cause damage to the depth sensor or barometer.
NOTICE
Avoid extreme shock and harsh treatment, because it can degrade the life of the product.
NOTICE
Do not store the device where prolonged exposure to extreme temperatures can occur, because it can cause permanent damage.
NOTICE
Discontinue use if the device is damaged or if it is stored at a temperature outside the specified storage temperature range.
GUID-EBD9D9CA-112E-4044-A2C9-354D565B9A10 v1
September 2025
