Specifications
Battery type
Rechargeable, built-in lithium-ion battery
Water rating
10 ATM1
Dive (EN 13319)2
Decompression model
Bühlmann ZHL-16C
Operating and storage temperature range
From -20º to 60ºC (from -4º to 140ºF)
Underwater operating temperature range
From 0° to 40°C (from 32° to 104°F)
Charging temperature range
From 0º to 45ºC (from 32º to 113ºF)
Wireless frequency and transmit power
2.4 GHz: < 5.4 dBm maximum
Depth sensor
Accurate from 0 m to 100 m (0 ft. to 328 ft.) complying with EN 13319
Resolution (m): 0.1 m until 99.9 m, 1 m at 100 m
Resolution (ft.): 1 ft.
Inspection interval
Inspect parts before each use for damage. Replace parts as needed.3
1 The device withstands pressure equivalent to a depth of 100 m. For more information, go to www.garmin.com/waterrating.
2 Designed to comply with CSN EN 13319.
3 Aside from normal wear and tear, performance is not affected by aging.
GUID-EBD9D9CA-112E-4044-A2C9-354D565B9A10 v3
September 2026
