NMEA 2000 Considerations
If you are connecting to an existing NMEA 2000® network, identify the NMEA 2000 power cable. Only one NMEA 2000 power cable is required for the NMEA 2000 network to operate properly.
A NMEA 2000 Power Isolator (010-11580-00) should be used in installations where the existing NMEA 2000 network manufacturer is unknown.
If you are installing a NMEA 2000 power cable, you must connect it to the boat ignition switch or through another in-line switch. NMEA 2000 devices will drain your battery if the NMEA 2000 power cable is connected to the battery directly.
You can connect your device to a NMEA 2000 network on your boat to share data from NMEA 2000 compatible devices such as a GPS antenna or a VHF radio. The necessary NMEA 2000 cables and connectors are sold separately.
This device is not powered through the NMEA 2000 network. You must connect the device to a power source .
If you are unfamiliar with NMEA 2000, you should read the Technical Reference for NMEA 2000 Products at garmin.com/manuals/nmea_2000.
The port labeled NMEA 2000 on the cradle is used to connect it to a standard NMEA 2000 network.
Item |
Description |
ECHOMAP™ Ultra 2 16xsv device |
GPS antenna or other NMEA 2000 device |
Ignition or in-line switch |
NMEA 2000 power cable |
NMEA 2000 drop cable |
12 Vdc power source |
NMEA 2000 female terminator or backbone extension cable |
NMEA 2000 T-connector |
NMEA 2000 male terminator or backbone extension cable |
