Range Card
Customizing the Range Card Fields
NOTE:
  1. From the Applied Ballistics® app, press Upper-right button.
  2. Select Range Card.
  3. Press Upper-right button, and select Change Fields.
  4. Press Lower-left button or Middle-left button to change the field.
  5. Press Upper-right button to select the field to customize.
  6. Select a field.
  7. Press Lower-right button to save your changes.
Editing the Range Increment
  1. From the Applied Ballistics app, press Upper-right button.
  3. Press Upper-right button, and select Range Increment.
  4. Enter a value.
Setting the Base Range
  3. Press Upper-right button, and select Base Range.
  4. Enter a value.
GUID-EA668398-46E4-42E4-8163-12F6CB299F0E v5
February 2026
