Calling from the Phone App
NOTE: This feature is available only if your watch is connected to a compatible phone using Bluetooth® technology.
  1. From the watch face, press Upper-right button.
  2. Select Phone.
  3. Select an option:
    • To dial a phone number using the dial pad, select Dial pad, dial the phone number, and select Answer phone call.
    • To call a phone number from your contacts, select Contacts, select a contact name, and select a phone number (Adding Contacts).
    • To view recent calls made or received on the watch, swipe up.
      NOTE: The watch does not sync with the recent calls list on your phone.
  4. Wait while the call connects.
  5. Swipe up for call options.
  6. Select an option:
    • To mute the watch microphone, select Microphone.
    • To adjust the watch speaker volume, select Volume.
    • To transfer the call from your watch to your connected phone, select Transfer call to phone.
  7. Select Reject phone call to end the call.
GUID-EA668398-46E4-42E4-8163-12F6CB299F0E v7
September 2026
