Editing an Alarm
Select an option:
From the watch face, hold
From the watch face, press
Hold
- Select .
- Select an alarm.
Select an option:
To turn the alarm on or off, select Status.
To change the alarm time, select Time.
To set an alarm to gently wake you in the 30-minute window before your scheduled alarm based on optimal sleep timing, select Smart Wake.
NOTE: Your alarm will always go off at your selected time in addition to any earlier alarms. For example, if you set your alarm for 8:00 am, the alarm may gently alert you to wake up some time between 7:30 and 8:00 am. -
To set the alarm to repeat regularly, select Repeat, and select when the alarm should repeat.
To select the type of alarm notification, select Sound & Vibe.
NOTE: You can also preview the alarm sound, adjust the volume, and select vibration options. Select Quiet Start if you want your alarm to start quietly and then get louder. -
To turn the backlight on or off with the alarm, select Backlight.
NOTE: This feature is not available for tactix® 8 AMOLED models. -
To select a description for the alarm, select Label.
Select an option:
To save your edits, select Done.
To delete the alarm, select Delete.
Parent Topic: Setting an Alarm
