Data Fields
Some data fields require you to be navigating or require ANT‍+® accessories to display data.
24hr Max Temp.
The maximum temperature recorded in the last 24 hours. Your device must be connected to a wireless temperature sensor for this data to appear.
24hr Min Temp.
The minimum temperature recorded in the last 24 hours. Your device must be connected to a wireless temperature sensor for this data to appear.
Accuracy Of GPS
The margin of error for your exact location. For example, your GPS location is accurate to within +/- 12 ft. (3.65 m).
Alarm Timer
The current time of the countdown timer.
Ambient Pressure
The uncalibrated environmental pressure.
Ascent - Average
The average vertical distance of ascent since the last reset.
Ascent - Maximum
The maximum rate of ascent in feet per minute or meters per minute since the last reset.
Ascent - Total
The total elevation distance ascended since the last reset.
Average Lap
The average lap time for the current activity.
Barometer
The calibrated current pressure.
Battery Level
The remaining battery power.
Bearing
The direction from your current location to a destination. You must be navigating for this data to appear.
Cadence
The number of revolutions of the crank arm or number of strides per minute. Your device must be connected to a cadence accessory for this data to appear.
Compass Heading
The direction you are moving based on the compass.
Course
The direction from your starting location to a destination. Course can be viewed as a planned or set route. You must be navigating for this data to appear.
Current Lap
The stopwatch time for the current lap.
Date
The current day, month, and year.
Depth
The depth of the water. Your device must be connected to a NMEA® 0183 or NMEA 2000® device capable of acquiring the water depth.
Descent - Average
The average vertical distance of descent since the last reset.
Descent - Maximum
The maximum rate of descent in feet per minute or meters per minute since the last reset.
Descent - Total
The total elevation distance descended since the last reset.
Distance To Destination
The remaining distance to the final destination. You must be navigating for this data to appear.
Distance To Next
The remaining distance to the next waypoint on the route. You must be navigating for this data to appear.
Elevation
The altitude of your current location above or below sea level.
Elevation Above Ground
The altitude of your current location above ground level (if maps contain sufficient elevation information).
Elevation - Maximum
The highest elevation reached since the last reset.
Elevation - Minimum
The lowest elevation reached since the last reset.
ETA At Destination
The estimated time of day when you will reach the final destination (adjusted to the local time of the destination). You must be navigating for this data to appear.
ETA At Next
The estimated time of day when you will reach the next waypoint on the route (adjusted to the local time of the waypoint). You must be navigating for this data to appear.
Glide Ratio
The ratio of horizontal distance traveled to the change in vertical distance.
Glide Ratio To Dest
The glide ratio required to descend from your current position to the destination elevation. You must be navigating for this data to appear.
GPS Elevation
The altitude of your current location using GPS.
GPS Heading
The direction you are moving based on GPS.
GPS Signal Strength
The strength of the GPS satellite signal.
Grade
The calculation of rise (elevation) over run (distance). For example, if for every 10 ft. (3 m) you climb you travel 200 ft. (60 m), the grade is 5%.
Heading
The direction you are moving.
Heart Rate
Your heart rate in beats per minute (bpm). Your device must be connected to a compatible heart rate monitor.
Lap Distance
The distance traveled for the current lap.
Laps
The number of laps completed for the current activity.
Last Lap Time
The stopwatch time for the last completed lap.
Location (lat/lon)
The current position in latitude and longitude regardless of the selected position format setting.
Location (selected)
The current position using the selected position format setting.
Location of Destination
The position of your final destination. You must be navigating for this data to appear.
Odometer
A running tally of distance traveled for all trips. This total does not clear when resetting the trip data.
Off Course
The distance to the left or right by which you have strayed from the original path of travel. You must be navigating for this data to appear.
Pointer
An arrow points in the direction of the next waypoint or turn. You must be navigating for this data to appear.
Speed
The current rate of travel.
Speed Limit
The reported speed limit for the road. Not available in all maps and in all areas. Always rely on posted road signs for actual speed limits.
Speed - Maximum
The highest speed reached since the last reset.
Speed - Moving Avg.
The average speed while moving since the last reset.
Speed - Overall Avg.
The average speed while moving and stopped since the last reset.
Stopwatch Timer
The stopwatch time for the current activity.
Sunrise
The time of sunrise based on your GPS position.
Sunset
The time of sunset based on your GPS position.
Temperature
The temperature of the air. Your body temperature affects the temperature sensor. Your device must be connected to a wireless temperature sensor for this data to appear.
Temperature - Water
The temperature of the water. Your device must be connected to a NMEA 0183 device capable of acquiring the water temperature.
Time of Day
The current time of day based on your current location and time settings (format, time zone, daylight saving time).
Time To Destination
The estimated time remaining before you reach the destination. You must be navigating for this data to appear.
Time To Next
The estimated time remaining before you reach the next waypoint in the route. You must be navigating for this data to appear.
To Course
The direction in which you must move to get back on the route. You must be navigating for this data to appear.
Total Lap
The stopwatch time for all the completed laps.
Track Distance
The distance traveled for the current track.
Trip Odometer
A running tally of the distance traveled since the last reset.
Trip Time
A running tally of the total time spent moving and not moving since the last reset.
Trip Time - Moving
A running tally of the time spent moving since the last reset.
Trip Time - Stopped
A running tally of the time spent not moving since the last reset.
Turn
The angle of difference (in degrees) between the bearing to your destination and your current course. L means turn left. R means turn right. You must be navigating for this data to appear.
Velocity Made Good
The speed at which you are closing on a destination along a route. You must be navigating for this data to appear.
Vertical Dist to Dest
The elevation distance between your current position and the final destination. You must be navigating for this data to appear.
Vertical Speed
The rate of ascent or descent over time.
Vertical Speed To Dest
The rate of ascent or descent to a predetermined altitude. You must be navigating for this data to appear.
Waypoint At Dest
The last point on the route to the destination. You must be navigating for this data to appear.
Waypoint At Next
The next point on the route. You must be navigating for this data to appear.
Copyright © Garmin. All rights reserved.GUID-EA40F185-39D1-4C3B-B512-7AA823FA3DB5 v1
