Profile
Adding a Profile
You can add a .pro file that contains profile information by creating it using the Applied Ballistics Quantum™ app and transferring the file to the AB folder on the device. You can also create a profile using your Garmin® device.
  1. From the Applied Ballistics® app, press Upper-right button.
  2. Select Profile.
  3. Select an option:
    • To create a brand new profile, select + Profile
    • To create a new profile based on an existing profile, select the profile, select Copy, and enter a name.
Editing a Profile
  1. From the Applied Ballistics app, press Upper-right button.
  2. Select Profile.
  3. Select a profile.
  4. If necessary, select Rename, and enter a name.
  5. Select Properties.
  6. Select an option:
    NOTE: Some options only appear when you enable the Advanced Settings option.
    • To enter the bullet properties, select Bullet Data, and select an option.
      TIP: You can select Bullet Library to automatically enter bullet properties from the Applied Ballistics bullet database. If you manually enter the bullet properties, you can find the information on the bullet manufacturer's website.
    • To enter the gun properties, select Gun Data, and select an option.
    • To enter the scope properties, select Scope, and select an option.
    • To calibrate the muzzle velocity to provide a more accurate solution in the supersonic range for your firearm, select Calibrate Muzzle Velocity, select an option, and select Apply.
    • To calibrate the custom drag factor, select Calibrate Custom Drag Factor, select an option, and select Apply.
    • To edit the muzzle velocity temperature table, select MV Temp Table, press Upper-right button, select Edit, and select a value to edit.
      NOTE: If necessary, you can select Clear MV-Temp to reset the muzzle velocity temperature table back to the default values.
    • To calibrate the drop scale factor to provide a more accurate solution at or beyond the transonic range for your firearm, select Drop Scale Factor > Calibrate DSF, select an option, and select Apply.
      NOTE: Garmin recommends you calibrate the muzzle velocity prior to the drop scale factor. After you calibrate the drop scale factor, you can select View DSF Table to view the drop scale factor table. If necessary, you can select Clear DSF Table to reset the drop scale factor table to the default values.
Deleting a Profile
NOTE: You cannot delete your current profile.
  2. Select Profile.
  4. Select Delete.
Selecting a Different Profile
  2. Select Profile.
  4. Select Set as current.
Customizing the Profile Data Screen
  1. During an Applied Ballistics activity, press Lower-left button to scroll to the profile data screen.
  2. Press Upper-right button, and select Change Fields.
  3. Press Lower-left button or Middle-left button to scroll to a field.
  4. Press Upper-right button to select the field to change.
  5. Press Lower-left button or Middle-left button to scroll through the fields.
  6. Select a field.
  7. Press Lower-right button to save your changes.
GUID-EA112C95-8563-4EED-AADF-2AADFBB95646 v5
September 2026
