Setting Your Heart Rate Zones
The device uses your user profile information from the initial setup to determine your default heart rate zones. The device has separate heart rate zones for running and cycling. For the most accurate calorie data during your activity, you should set your maximum heart rate. You can also set each heart rate zone. You can manually adjust your zones on the device or using your Garmin Connect™ account.
  1. Hold Letter B symbol.
  2. Select Settings symbol > User Profile > Heart Rate Zones.
  3. Select Default to view the default values (optional).
    The default values can be applied to running and cycling.
  4. Select Running or Cycling.
  5. Select Preference > Set Custom.
  6. Select Max. HR, and enter your maximum heart rate.
  7. Select a zone, and enter a value for each zone.
Copyright © Garmin. All rights reserved.GUID-E963C6EE-40F3-48EB-9F4F-52C1A15FF07D v2
