Activities and App Settings
These settings allow you to customize each preloaded activity app based on your needs. For example, you can customize data screens and enable alerts and training features. Not all settings are available for all activity types and vary by watch model.
Hold
, select
, select an activity, and select the activity settings.
- Accent Color
Sets the accent color of each activity to help identify which activity is active.
- Alerts
Sets the training alerts for the activity (Alerts).
- Altimeter
Displays the pressure altitude, or GPS altitude, when the device has a GPS fix (Altimeter Readings).
- Auto Fly
In watch mode, allows a flight activity to begin automatically when the detected climb rate exceeds a specified speed.
- Auto Lap
Sets the options for the Auto Lap® feature (Auto Lap).
- Auto Pause
Sets the device to stop recording data when you stop moving or when you drop below a specified speed (Using Auto Pause).
- Auto Rest
Enables the device to automatically detect when you are resting during a pool swim and create a rest interval.
- Auto Run
Enables the device to detect ski runs automatically using the built-in accelerometer.
- Auto Scroll
Enables you to move through all of the activity data screens automatically while the timer is running (Using Auto Scroll).
- Auto Set
Enables the device to start and stop exercise sets automatically during a strength training activity.
- Club Prompt
Displays a prompt that enables you to enter which golf club you used after each detected shot.
- Data Screens
Enables you to customize data screens and add new data screens for the activity (Customizing the Data Screens).
- Driver Distance
Sets the average distance the golf ball travels on your drive.
- Edit Weight
Allows you to add the weight used for an exercise set during a strength training or cardio activity.
- Enable Videos
Enables instructive workout animations for a strength, cardio, yoga, or Pilates activity. Animations are available for pre-installed workouts and workouts downloaded from Garmin Connect™.
- Flight Timer
From the FLY app, allows the flight timer to start and stop automatically when your ground speed exceeds the value set in the Flight Timer Theshold option.
- Flight Timer Theshold
From the FLY app, allows the flight timer to start and stop automatically when your ground speed exceeds this value. For example, 30 kts.
- GPS
Sets the mode for the GPS antenna (Changing the GPS Setting).
- Pool Size
Sets the pool length for pool swimming.
- Scoring
Enables or disables scorekeeping automatically when you start a round of golf. The Always Ask option prompts you when you begin a round.
- Scoring Method
Sets the scoring method to stroke play or Stableford scoring while playing golf.
- Stat Tracking
Enables statistics tracking while playing golf.
- Status
- Tournament Mode
Disables features that are not allowed during sanctioned golf tournaments.
- Vibration Alerts
Enables alerts that notify you to inhale or exhale during a breathwork activity.
- Customizing the Data Screens
- Alerts
- Altimeter Readings
- Auto Lap
- Using Auto Pause
- Using Auto Scroll
- Changing the GPS Setting
