Scanning All Channels
When you scan channels, the radio searches for channels that are broadcasting. When a channel is broadcasting, the radio pauses on that channel until the broadcast stops. After four seconds of inactivity on a channel, the radio resumes scanning.
NOTE: When you turn on ATIS (Automatic Transmitter Identification System), the radio does not scan or save channels.
  1. Select SCAN > ALL.
  2. Select an option:
    • To exclude the currently active channel from subsequent passes and resume scanning, select SKIP.
    • To scan channel 16 each time another channel is scanned, select +CH16.
      For example, the radio scans channel 21, channel 16, channel 22, channel 16, and so on.
      +CH16 appears on the device screen.
    • To scan channel 16 in its usual order, select -CH16.
      For example, the radio scans channel 14, channel 15, channel 16, channel 17, and so on.
    • To end the scan, select EXIT.
      The radio stops scanning and tunes to the last used, active channel.
GUID-E5A56C73-E63C-479F-BDB2-198E7FB08115 v1
September 2024
