Connecting the Device to Your Computer
You can connect the device to your computer using a USB cable.
  1. Plug the small end of the USB cable into the port on the device.
  2. Plug the larger end of the USB cable into a port on your computer.
  3. From your Alpha® XL device, select Tap to Connect to Computer.
A picture of your device connected to a computer appears on the device screen.
Depending on your computer operating system, the device appears as either a portable device, a removable drive, or a removable volume.
NOTE: Mac® computers do not detect the device by default. You must use Garmin Express™ software to interact with files on your device.
GUID-E4961C4C-A75C-4277-A125-70E674AFA2F4 v3
December 2025
