Adventurous Routing
Garmin Adventurous Routing™ is a special route calculation mode designed to prefer routes featuring more hills and winding roads. You can choose a level of adventurous routing to fine-tune the route calculation to your preferences. If you prefer winding roads and hills even if it increases travel time, distance or fuel consumption, choose a higher level of adventurous routing.
For each vehicle profile, you can select a level of adventurous routing as the default route calculation mode (Editing a Vehicle Profile). Regardless of the current vehicle profile, you can always select Adventurous routing to use adventurous routing when starting, planning, or editing a route.
GUID-E4961C4C-A75C-4277-A125-70E674AFA2F4 v3
December 2025
