Using In-Call Options
In-call options are available when you answer a call. Some options may not be compatible with your phone.
TIP: If you close the in-call options page, you can open it again by selecting Smartphone icon from any screen. You can also select the caller from the map.
  • To set up a conference call, select Add Call.
  • To transfer audio to your phone, select Call in Progress on Navigator.
    TIP: You can use this feature if you want to disconnect the Bluetooth® connection and remain on the call, or if you need privacy.
  • To use the dial pad, select Keypad.
    TIP: You can use this feature to use automated systems, such as voice mail.
  • To mute the microphone, select Mute.
  • To hang up, select End Call.
GUID-E4961C4C-A75C-4277-A125-70E674AFA2F4 v3
December 2025
