Display Settings
Select Settings > Display.
Brightness Slider
You can move the slider to adjust the display brightness.
Orientation
Allows you to set the display to portrait (vertical) or landscape (horizontal).
Color Mode
Allows you to select day or night color mode. If you select the Auto option, the device automatically switches to day or night colors based on the time of day.
Display Timeout
Allows you to set the amount of idle time before your device enters sleep mode while using battery power.
External Power Prompts
Allows you to set power management options when the device loses external power.
Screenshot
Allows you to take a picture of the device screen. Screenshots are saved in the Screenshot folder of the device storage.
GUID-E4961C4C-A75C-4277-A125-70E674AFA2F4 v3
December 2025
