Fitting the Collar on Your Dog
CAUTION
To prevent irritation from the contact points, remove the collar for at least eight hours out of every 24-hour period.
CAUTION
This device is not intended for human use. Do not attempt to use on any person.
CAUTION
Do not spray the device or collar with harsh chemicals including but not limited to flea or tick spray. Always ensure that any flea or tick spray that is applied to the dog is completely dry before placing the collar on the dog. Small amounts of harsh chemicals can damage the plastic components and collar strap.
Before you can put the collar on the dog, you must pair the navigator and dog collar device (Methods to Add a Dog Collar Device to Your Navigator), and acquire satellite signals (Acquiring GPS Signals).
In order to effectively train the dog, the collar must fit the dog properly. If the collar is too loose or positioned incorrectly, stimulation may be inconsistent. This can delay or prevent successful training.
  1. Position the collar with the communication antenna pointing up, the GPS antenna facing up, the LEDs facing forward, and the contact points against the neck.
  2. Place the collar around the middle of the dog's neck.
  3. Tighten the strap so that it is snug around the dog's neck, and fasten the buckle.
    NOTE: The collar should fit tightly and should not be able to rotate or slide on the dog's neck. The dog must be able to swallow food and water normally. You should observe your dog's behavior to verify that the collar is not too tight.
    Dog wearing the dog collar device
  4. Wiggle the device to work the contact points through the dog's coat.
    NOTE: The contact points must have contact with the dog's skin to be effective.
  5. If the strap is too long, cut off the excess, leaving at least 7.62 cm (3 in.) to spare.
    TIP: You can mark the hole used to fasten the buckle for future reference.
GUID-E4961C4C-A75C-4277-A125-70E674AFA2F4 v3
December 2025
