Training Menu
The training menu 1 contains shortcuts to training commands, applications, device actions, and utilities. You can customize the training menu pages to best suit your tracking and training needs. You can select Dog sitting to open the training menu from any page.
Screenshot of the map with a callout
Moving the Training Menu Button
If necessary, you can move the training button to another area on the screen.
  1. Hold Dog sitting.
    Possible button positions appear on the screen.
  2. Drag the button to a new position.
Customizing the Training Buttons
You can assign an application shortcut, device action, or utility to a training button. If a compatible dog collar device is paired, you can also add a dog training command to a training button. You can add multiple pages of training buttons. For example, this is useful when training multiple dogs.
NOTE: Training features are not available with all dog collar device models.
  1. Select Training Setup.
  2. Select Add from the empty button you are customizing.
  3. Select an option:
    • To add a dog training command to the training button, select Training Command, select the name of the dog to command, and select a training method.
    • To add an application to the training button, select Applications, and select an application.
    • To add a device action to the training button, select Device Actions, select an action, and if necessary, select a dog or group to complete the command setup.
    • To add a utility to the training button, select Utilities, and select a utility.
  4. If selecting a dog training command, select momentary (M), continuous (C), tone (T), vibration (V), or light (L).
  5. If selecting a dog training command, select Zoom out or Zoom in to choose the intensity level.
  6. If you are using traditional stimulation mode, select LOW, MED, or HI.
TIP: If you want to customize more than three buttons, you can add another page of training button commands.
Using the Training Menu
Before you can use this feature, you must customize your training buttons with dog training commands (Customizing the Training Buttons).
  1. From any screen, select Dog sitting to open the training menu.
  2. If necessary, select Left arrow or Right arrow to move through training pages.
    • To activate a training command, application, device action, or utility, select a button.
    • To change training command functions, select Stimulation settings, and select a training command.
    • To lock the training menu and prevent accidental touches, select Unlock.
Changing the Intensity Level
  3. Select Stimulation settings, and select a training command.
  4. Select Zoom out or Zoom in to choose the intensity level.
Dog Training Options
Select Training Setup > Wrench.
Training Menu Position
Sets the position of the training menu on the left or right side of the screen.
NOTE: The training menu position can be adjusted only for the landscape screen orientation.
Training Defaults
Sets the default buttons and layout for new training collars (Default Training Settings).
Stimulation
Sets the stimulation type (Linear and Traditional Stimulation).
Adjust Stim Each Use
Enables the option to adjust the stim level after each use.
Play Tone on Training Command
Enables a tone to play each time you use a training command.
From the main menu, select Training Setup > Wrench > Training Defaults.
Add When Paired
Automatically sets default training modes for each button when a new dog collar is paired.
Button Layout
Sets the number of training buttons for each dog.
Training Button 1
Sets the default training mode for the first training button.
Training Button 2
Sets the default training mode for the second training button.
Training Button 3
Sets the default training mode for the third training button.
GUID-E4961C4C-A75C-4277-A125-70E674AFA2F4 v3
December 2025
