Calibrating Pitch and Roll
You can set the angle of your vehicle to zero at any time.
  1. Park your vehicle on a flat, level surface.
  2. Adjust the position of your device in the mount so you can comfortably view the screen.
  3. Select Apps icon > Pitch and Roll > Calibrate.
The values for pitch and roll reset to 0 degrees.
WARNING
To maintain the best accuracy, you must calibrate pitch and roll each time you reposition your device.
GUID-E4961C4C-A75C-4277-A125-70E674AFA2F4 v3
December 2025
